DRTDEVL
Apr 25, 2018Explorer
Well, I got a deal on a pure sine wave 2500w (5000w peak) inverter with remote, so I reduced the capacity a little. Otherwise, I'm forging ahead as planned: Install RV outlet at junction in power cable box, wire inverter to other end in the generator bay, install a 4/0 positive cable to inverter with the 100a breaker, install a second 2 awg chassis ground and a second 2 awg cable from the battery negative to ground, and replace the single group 24 battery with a pair of group 31 batteries (giving 210 aH compared to the current 95 aH).
I also discovered that a new power center will be easy enough to put in this year, with a 3-stage charger/maintainer and all the 12v circuits to go with the 115 vac output main breaker as my current setup has. I just need to check the amp ratings and size measurements I need when I pull it back out of storage Friday to determine which panel to order.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
