DRTDEVL's avatar
DRTDEVL
How to figure out what electrical components are present.
OK, I have almost finished prepping the RV I inherited from my grandparents for actual use, and plan to use it extensively this summer.
The specs:
1980 Winnebago Minnie Winnie 20RG
1979 Dodge CB300 Chassis with 10,400 GVWR heavy package.
5.9L 360 c.i., 727 Transmission
Generator Prep package (but no generator)
There is no power inverter, only a power converter and "charge sentry" system to keep the 12v up and running when plugged in. At least, I don't think there is an inverter, as I have never seen one nor any switch or remote panel that would turn on the 110v system when not hooked to shore power.
I plan on mounting a 3000w continuous (6000w peak) inverter with a remote panel in the generator bay, as there is already a large gauge positive battery cable running there as well as an electrical junction box to wire a generator to the 110 system. This seems to be the most logical choice for me... but I don't know if there is an automatic power transfer switch installed from the factory as a part of the generator prep package. Later today, I am going to remove the back seat and check to see what the back side of the converter/breaker/fuse panel looks like, but I am not sure if I would recognize an automatic transfer switch from 38 years ago. If not, I can always try to remember to turn off the inverter prior to plugging into shore power, but I would like to make it "dummy proof" in case someone else is hooking it up in the future.
Anyone know much about these old units?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
