CA_Traveler
Jun 11, 2023Explorer III
Continuity may not be meaningful since a single bulb etc could have low resistance. Have you connected 12V to the circuit and a fuse blew?
If you actually have a short what fuse blew? Add a light bulb in series to that circuit and it will be full brigntness with a short. Then as you open downstream wiring and when the light turns off you can isoate the problem and resolve as needed.
And a wire tracer can be very useful in determine wire routing.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
