Bill_Satellite
Aug 08, 2017Explorer II
5thwheeleroldman wrote:
My TV is a new Samsung flat screen. The only coax input on the back of it says "antenna". Wonder if I could hook the park tv coax into that? It also has a couple of hdmi plugins, a usb port and the little red, yellow and white plugs.
This is exactly what you want to do!!!! However, it might be even easier than that! Outside in one of the bays where your power cord or water connections are you might have a coax connection labled CABLE. If so, you connect the campground cable to that connection and then go inside and push the tiny little button on the wall plate near your TV that is a booster for your TV antenna. With that power off, the incoming cable signal will be sent to the TV instead of the roof TV antenna signal. You do a new channel search on the TV but select CABLE instead of ANTENNA and you are watching cable TV in no time!
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
