fondon's avatar
fondon
park cable
I'm having an issue with my cable in the coach, bad wire dont have much time to do any trouble shooting getting ready to head out and was wondering is there a device that can be hooked up to the park coax cable and transmit it wireless to my tv's, thanks for any help.
  • X3, only I'd say to stop at a thrift store on your travels and pick up 50' for a buck or two.
    When mine started acting up, I too thought it was the coax between the wet compartment where the incoming cable is attached and the electronics cabinet at the front of the RV.
    No, it was the switching unit that was bad. A direct connection from the end of the cable in that cabinet to the TV was all it took to clear up the signal. No more than 3 feet long and a male to male coupler. Cost all of $1.25. Now I need to fix or replace that switch box.
  • DSDP Don wrote:
    Yes....you can add a wireless unit, but you would have to get to the back of the TV to connect it. If you have to do all that, just buy 50' of coax at Walmart, plug it into the TV and run it out a window when you need it. Once you get back, you can fix the problem, have a spare cable if needed again and save on buying a wireless device.
    X2
  • Yes....you can add a wireless unit, but you would have to get to the back of the TV to connect it. If you have to do all that, just buy 50' of coax at Walmart, plug it into the TV and run it out a window when you need it. Once you get back, you can fix the problem, have a spare cable if needed again and save on buying a wireless device.
