DOTLDaddy
Aug 08, 2017Nomad
road-runner wrote:dougrainer wrote:
ANTENNA is the EXACT same as Cable input from the Campground. READ the set up instructions for the TV as it relates to connecting Coax for the TV. Once you are connected to Campground Cable with standard Coax cable, you will have to go into the TV Antenna set up screen and TELL the TV you are on CABLE, not Antenna and then it will walk you thru programming the Campground Cable stations. HDMI/USB and the yellow/Red/White have nothing to do with Cable or Antenna. They have nothing to do with what you want to do. Doug
PS, you do not have to order anything.
This post nails it.
X2
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
