wowens79
Aug 10, 2017Explorer III
MrWizard wrote:wowens79 wrote:
One other thing to throw out there. Some of the new cheaper TV's don't have a tuner built into the TV, and some have an analog tuner, but not a digital (QUAM) tuner.
Some campgrounds you have to pick up a DTA (Digital to Analog) box from the office if the cable company encrypts its signal. Other companies don't encrypt, and you can just plug directly into the TV.
Unfortunately there are lots of variables.
if it doesn't have a tuner
its NOT a TV
IT IS a display monitor or home theater display that requires a separate tuner
by definition, its not a TV if it doesn't have a tuner
i have not seen anything adv as a TV with no tuner
I see them all the time that don't have a QUAM tuner in them. I work for a small cable company that uses a digital signal, but we do not encrypt so that the customer does not have to have a box on every tv. There are numerous brands that have an OTA tuner, but will not tune the digital signal from coax. You typically see this on the budget brands (Westinghouse, Hisense, Element etc).
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
