- RoyBExplorer IIMy 2010 Ford has this OEM Brake Controller built-in
Google Image
It also has the 4-way and 7-way dual connector on the rear of the truck...
Google Image
It also has the 2-inch receiver hitch on the rear of the truck...
My 2004 F150 truck also had the dual 7-way and 4-way Brake controller connections on the rear and had the BRAKE CONTROLLER harness available under the dash and it plugged directly into the Prodigy P2 Brake Controller that I purchased separately ...
Roy Ken - 2oldmanExplorer IIIs there an owner's manual anywhere around?
- BFL13Explorer II
Binfordtexas wrote:
BFL13 wrote:
There is such a thing as a four wire off a 7-pin back at the bumper.
For the bumper 7-pin to work any trailer brakes you need a brake controller in the cab. It will have a Dodge (in this case) adapter plug that gets to the 7-pin.
So I would just need to purchase a controller and wire to the 7 pin?
You need a truck brand adapter to go the connector down by the pedals in the truck. In your case a Dodge adapter, not a Ford's or Chev's. Might come with the controller or not.
It explains that in the brake controller's user's manual. - My old Ford had a harness near the driver's feet to be connected to an aftermarket controller. Check if yours has similar.
Check your 7 pin connector actually functions. You will not have a brake signal but you can check the rest is connected and operating.- Toolman52660Explorer
If you have someone pushing on the brakes while you check it shouldn’t brake work then?
- Grit_dogNavigator III
That’s not how that works.
And you’re replying to a question that was answered in 2017.
- Bionic_ManExplorerYes, you need a brake controller in order for electric trailer brakes to work from your truck.
- BinfordtexasExplorer
So I would just need to purchase a controller and wire to the 7 pin? - BFL13Explorer IIThere is such a thing as a four wire off a 7-pin back at the bumper.
For the bumper 7-pin to work any trailer brakes you need a brake controller in the cab. It will have a Dodge (in this case) adapter plug that gets to the 7-pin. - LadyRVerExplorer IIMy 2013 Dodge Ram 2500 has a built-in brake controller. It is right below the radio with two small handles you sort of squeeze together to set the braking power.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
