The_Next_Hill
May 23, 2013Explorer
How to Replace Norcold freezer door hinge assembly?
On the N41 and N51 Norcold refrigerators, if you notice the freezer door no longer closes properly, it may be a problem with either the LH or RH torsion spring assembly.
When I noticed the door no longer had enough spring force to keep it closed against the gasket, I removed the door to check it out. I found the right hand plastic assembly had cracked and would no longer hold the spring tab in the correct position.
A replacement for the LH assembly is part No. 619042 and for the RH assembly is part No. 619041. They can be purchased from several Norcold parts sources for about $8-10.
The question I have is how to put the door back in place and keep tension on the springs while doing so. Maybe it's a 3-person job? ( Hold the door in place, wind tension on both assemblies, and then screw in 4 small screws to the bottom of the door.)
There must be a simple solution. Would appreciate any help. Thanks, The Next Hill
