MrWizard
Oct 06, 2016Moderator
no offense to the OP
but you ARE using 50amps of 120vac not just 30amps
you are able to use a 30amp SITE, because you also use the 20amp outlet
if there was NO duplex outlet, you would be limited to 30amp only , and only (1) a/c
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
