Lantley
Oct 06, 2016Nomad
MrWizard wrote:
no offense to the OP
but you ARE using 50amps of 120vac not just 30amps
you are able to use a 30amp SITE, because you also use the 20amp outlet
if there was NO duplex outlet, you would be limited to 30amp only , and only (1) a/c
I agree that the device uses 30+20=50 amp total not just 30
I did say 30 amp site however. Most (not all) 30 amp sites will have a 20 amp outlet available.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
