katysdad
Mar 24, 2014Explorer
Don't know what model you have, but on mine you pull the bottom front panel and the water pump is on the bottom right. twist the strainer about 1/4 turn to left and it will pull straight out. It will dump about 1/2 pint of water out if you ran the drain cycle, now all the water is out of the drum and drain hose. No need for antifreeze. Have not tried blowing air thru the valves.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
