opnspaces
Mar 20, 2021Navigator III
Does the water heater work on propane and only 12 volts?
Does the water heater work when plugged into shore power?
Have you checked the 12 volt fuses in the fuse panel?
If you open the water heater compartment are there any burn marks or melting wires?
Can you tell us what you have tried or what you have noticed when you try? Is there a clicking sound when you try to light it on gas?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
