wealthwise
Aug 15, 2013Explorer
Thanks for the suggestions, I just came back from checking the connections all seem solid, checked the inline fuse it's good, but what I just noticed is one my parallel batteries up front is at 9.6 volts (looks like cells are dry, going to add some distilled water and see if it helps) and when I try to charge by running the engine the voltage doesn't seem to go up, so now I have a new problem a dying battery, and yes it looks like the pump is wired to that battery, so if the voltage is too low maybe that's why the pump won't activate? I was going to jump the connection to the other battery since it's fully charged and see if that will do the trick, at least so I can test, what do you guys think?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
Related Content
- Feb 01, 2026Community Alumni
