tarnold's avatar
tarnold
HWH levelers, again
Posted several weeks ago about a problem that seemed to fix itself after awhile. Now out on the road and something else. HWH 325 with 6ksprings. Looking at the control panel, I’m going to describe as a baseball diamond. 2nd base is the front. Before the up/down arrows worked in pairs, as supposed to. Now if I press the 2nd base up arrow only the right front goes down. Press the 3rd base up arrow, and only the left front goes down. Home plate up arrow and only the left rear goes down. Etc. so where did the “dual function” go?
  • Op. Yes they will all extend. After having busted that big mirror from uneven frame racking I’m overly cautious about uneven lifting.
  • dougrainer wrote:
    HOW LONG are you giving the system to extend? HWH Bi-Axis(Pairs) system does NOT always extend BOTH pairs at the exact same time. Sometimes one jack will extend 3 or more inches before the Paired jack starts. From your description, ALL jacks will extend by themselves just not in pairs. Doug
    That's how mine work. They never go down at the same time but they do operate in pairs.
  • HOW LONG are you giving the system to extend? HWH Bi-Axis(Pairs) system does NOT always extend BOTH pairs at the exact same time. Sometimes one jack will extend 3 or more inches before the Paired jack starts. From your description, ALL jacks will extend by themselves just not in pairs. Doug
