Profcadd's avatar
Profcadd
HWH Levellers
In cold weather, 32 and below, my front levellers jacks will retract. In warm weather like today at 60, they will not move.
Very weird. The rear jacks work fine. Any thoughts.
  • Chris Bryant wrote:
    To be clear, you are saying they will not stay extended, not that they will not retract when cold?
    No, he has an unusual problem. They extend and retract OK and stay extended as needed. His problem is---IF it is above 32 degrees outside the front jacks will only retract by the weight of the RV and once that happens the springs will not pull them up. If BELOW 32 degrees the jacks retract just fine with the springs. VERY unusual. Doug
  • you are going to have to either replace the cylinders, or have them rebuilt.
    call hwh, and get a rga number to return the cylinders. thats the cheapest way to go. any other thing you do is a temporary fix.
  • To be clear, you are saying they will not stay extended, not that they will not retract when cold?
  • Profcadd wrote:
    As I said: In warm weather they stay extended, they retract until the full weight is off them, but still the feet remain on the ground.
    The inner seals are bad. rebuild or replace. Doug
  • As I said: In warm weather they stay extended, they retract until the full weight is off them, but still the feet remain on the ground.
  • Gjac's avatar
    Gjac
    Explorer III
    Do they not retract at all or do they come in several ins then stop retracting with maybe 4 ins of the piston visible?
  • Profcadd wrote:
    I replaced the springs on the front jacks last summer.
    IF jacks retract when opening the manual T handles, but not with the touch pad, replace the 2 solenoids. IF they do NOT retract with the T handles, replace or rebuild both jacks. Doug
    I do not have a specific solution to your issue, but perhaps you can glean some advice by viewing HWH trouble shooting manual for your specific model. Click here to view.
    Hope this helps and please let us know if you find the solution so we can benefit.
    Thanks,
    Bill
  • 1. Seals bad
    2. Spray jacks with liquid Nitrogen when above 32 degrees:B
    3. OPEN the manual T handles on the solenoids(the center 2 control the front jacks) and see if they retract.
    4. Your year model probably needs new springs. Doug
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
