dougrainer
Aug 23, 2016Nomad
1. There is not set rule on which Battery Bank powers the Jack system
2. IF HWH, the touch pad at the dash will state HWH. It will also state AUTOMATIC LEVELING or NOT. The correct answer to if Auto leveling or Not is important to your Jack down light coming on. IF the Batteries are 7 years old you need to replace regardless as a maintenance issue.
3. Yes, a Bad battery or bad cable connections can cause the jacks to not operate. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
