MrWizard
Dec 06, 2018Moderator
spring return or power down power up
most likely problem, the valve for jack is NOT opening
could be a bad relay in the control, bad control board, or bad hydraulic valve/coil
manually 'forcing it down', either spring tension or internal vacuum is going to pull it back up
it needs hyd pressure to hold it down
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
