- Edd505Explorer
azdryheat wrote:
I spray mine with a silicon lube.
Per the Lippert manual - MEXICOWANDERERExplorerGood cylinders are hard chromed and hard chrome is porous. So oil is contained in the plating itself.
Something that could help would be a bellows that would fit the cylinder, like seen on some some struts.
The cylinders on caterpillar equipment are exotic: Double wipers, multi seals including nylon and teflon
With a price to match :( - RJsfishinExplorerNever heard of a hydraulic cyl that had to be cleaned or lubed.
Mine get cleaned and lubed every time they go out and back in.
Been workin for 17 yrs. - Here is the level it manual. See page 9 for maintenance.
Level it Manual - Cummins12V98Explorer IIIClean and wipe down with silicone spray, right from Lippert.
- azdryheatExplorerI spray mine with a silicon lube.
- KountryguyExplorerI think they are level up by lippert. They are on a 2013 Mobile Suites fifth wheel.
- What brand of jacks do you have?
- KountryguyExplorerThanks Pigman1. Very helpful. I do not have HWH jacks, but much of the info still applies.
- pigman1ExplorerAre you talking about HWH jacks? HWH has some very specific directions on these hydraulic rams. There is other info presented in HWH instructions. Download it and read.
ISSUE DATE:
HWH CORPORATION
R
Cleaning the jack and jack rod.
In general, HWH jacks require no regular maintenance. Under normal circumstances, lubrication of jack rods is not necessary or advised.
If a jack gets coated with dirt or mud it is advisable to clean
the jack. It is acceptable to clean the jack as a part of normal maintenance but is not required.
Note: The 9000# and 16,000# kick down jacks have a roller bearing above the actuator rod.
This bearing must roll freely for proper operation of the jack. It is a good idea during regular maintenance
that this bearing is checked to make sure it does roll freely. If the bearing is frozen or does not roll freely,
use WD-40 to loosen the bearing and then apply a few drops of motor oil (used is fine) to lubricate the
bearing. See diagrams on reverse side.
BLOCK FRAME AND TIRES SECURELY BEFORE CRAWLING UNDER
VEHICLE. DO NOT USE LEVELING JACKS OR AIR SUSPENSION TO SUPPORT VEHICLE
WHILE UNDER VEHICLE OR CHANGING TIRES. VEHICLE MAY DROP AND/OR MOVE
Basic cleaning of the complete jack assembly is accomplished with the use of soap and water.
Spaying the jacks with a spray wand at a car wash would be acceptable.
The only time a jack rod would need cleaning is if the jack has been extended for a period of time.
The jack should not be extended just to clean the rod.
WARNING:
If the jack is extended, use soap and water or WD-40 on the jack rod then wipe the rod dry with a clean cloth.
Do not use a dirty rag to wipe the jack rod or do not wipe the jack rod if it is coated with dirt.
This could scratch and damage the rod. Make sure to use water or WD-40 to loosen any dirt before
wiping the jack rod.
If the jack rod has been greased or silicone sprays have been used on the jack rod, use WD-40 to loosen
the grease or silicone and wipe the rod clean.
Having RV issues? Connect with others who have been in your shoes.24,285 PostsLatest Activity: Jul 22, 2025
