Odds are from your model year you have an HWH 300 series system. If so, the manual states and is true, EVERYTIME, you start the engine you MUST push the STORE button. 300 series HWH systems, the road/chassis system heat can cause the HYD fluid in the lines to expand slightly and a jack may extend up to a inch and by having the unit is STORE, the system is in hibernation and IF this happens the system comes on automatically, opens the offending solenoid and the jack auto retracts BEFORE the system light and alarm sounds. Doug
