mydrummerrocks's avatar
Jul 17, 2013
hydraulic leveling jack for class A
i have a 2001 winnebago chieftain and i'm to trying to figure out why when i extend the front jacks and then the back jacks, the back jacks retracted back up by themselves and i could not retract the front at all. then about 5 minutes later the control panel lost all power. i am stumped! anybody have any ideas or suggestions. its a hwh hydraulic leveling system 310 series, thanks!!!!
  • I don't know why they wouldn't retract, because you are manually opening the valves, and the springs retract them.
    I loose all power to my jacks and slide quite often. I gave up on trying to find the intermittent connection, and just wired around it thru a switch under the hood, which not only brings 12v power directly to the pump sillynoid, it also bypasses every saftey device, parking brake, etc etc.
  • Check and see hat make the jacks are. Should be HWH.
    Go to there web site. Check there trouble shooting page. I you can also contact them for the right answer.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
