mrad
Apr 08, 2024Explorer II
Just to be sure, the rig levels without problem. It is only when retracting that I have a problem, and it only started toward the end of last summer. Does this sound the same as the issue you were dealing with? Does the fuse automatically reset? I have not reset mune when it stops retracting. I just wait 10-15 seconds and then press the retract button again.
lightfoot
Apr 09, 2024Explorer III
I think it is similar. The existing circuit breaker is an automatic resetting one and it takes a short time, maybe 10-15 seconds, to reset which is what the 80amp breaker resolves. As long at the breaker is resetting, and you are OK with the time lag, and starting over, I would leave it alone. In my case it was doing it anytime I used the system. It became a pain.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
