TucsonJim
May 18, 2014Explorer II
It would not be a break in the wiring. As you first described, this is apparently a short circuit. Can you disconnect the circuit from the fuse panel side, then use a ohm-meter to check for short circuits.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
