CA_Traveler
May 18, 2014Explorer III
You can also replace the fuse with a bulb and and have someone watch it while you disconnect the ceiling wires to track down the short.
The ceiling wiring could be any combination of serial/parallel wiring. Once you identify the bad segment connect a temporary wire and make sure that all of the lights then work.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
