MrWizard
May 18, 2014Moderator
JimMartin wrote:newman fulltimer wrote:
Sounds like you screwed a screw into the wire.run a jumper wire from light to light until fuse blows.then you will know where the short is at
With all the lights unplugged and removed I still can't get the fuse panel to take a new fuse without it blowing.
That indicates the short circuit is between the first fixture in the string, and the fuse panel
Climb on the roof and look for new screws you put in
New roof , lights on center line of ceiling?
Possibly a screw at the ceiling vent closes to the fuse panel or fixture
That's where I would start
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
