westend
May 18, 2014Explorer
You don't need to move bulbs around, power them, and blow more fuses. A meter will diagnose where the short is located. With light circuit NOT POWERED (pull fuse), Put one lead on the (+) wire from the distribution center that feeds the light circuit and the other lead to known good (-)ground. Check for continuity. You should have continuity if there is a short in the circuit. Remove (+) from closest light fixture and observe for continuity. If you have continuity, the short is between distribution and that fixture. If not, the short is downstream from that fixture.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
