JimMartin
May 18, 2014Explorer
As far as removing the screw in the roof. That's not going to happen. New TPO roofing is all glue down.
I have unscrewed the wire were it goes into the fuse panel for now. There are only the four overhead double lights in the living area on this fuse. All the other ceiling lights in the RV are fine.
I decided to run a wire from the ceiling light in the hallway to the living area light. Going to try and do this by drilling thru the Styrofoam with a 24" long 3/8" drill bit, and then running a coat hanger thru it to feed the wires. Wish me luck!!
Do you think the fuse for the hallway ceiling light can handle 4 additional lights on it?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
