JimMartin
May 18, 2014Explorer
CA Traveler wrote:JimMartin wrote:
Going to try and do this by drilling thru the Styrofoam with a 24" long 3/8" drill bit, and then running a coat hanger thru it to feed the wires. Wish me luck!!
Do you think the fuse for the hallway ceiling light can handle 4 additional lights on it?
I'd first try a 1/8" fiberglass wire puller.
As for the fuse - maybe.
But how does this eliminate the short?
With the wire disconnected from the fuse panel it disconnects the bad wire, which will eliminate the short
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
