JimMartin
May 18, 2014Explorer
The new 3/8" plywood roof is put down with about 100 screws. Apparently one of those 100 plus screws has hit a wire. Unfortunately I can't back any of those screws out because the new rubber TPO roof is glued down and covering them all.
As far as the screws that hold all the 14" x 14" vents down, I will try and back them all out and see if that solves my problem.
What I mean by "wire disconnected from the fuse panel it disconnects the bad wire, which will eliminate the short" is that I'm no longer going to use that wire that goes from the fuse panel to the light. I will by pass it altogether.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
