JimMartin's avatar
JimMartin
I have a short somewhere? How do I find it?
Just installed a new roof on my 1999 Coachmen Mirada. Problem is that I must have pinched a wire somewhere? 12v Ceiling lights in my RV don't work now. Checked the fuse, it was blown, replaced it and it blew as I plugged it in. Removed all the light fixtures from the ceiling, unplugged them all from there 12v wiring. So now nothing should be powered up my that circuit right? Tried to put a new fuse in but it blew right away?
How can I find this break in the wiring? Do they sell a tracer of some sort that can test the wires and find a break? :?
  • newman fulltimer wrote:
    Sounds like you screwed a screw into the wire.run a jumper wire from light to light until fuse blows.then you will know where the short is at
    With all the lights unplugged and removed I still can't get the fuse panel to take a new fuse without it blowing.
  • Sounds like you screwed a screw into the wire.run a jumper wire from light to light until fuse blows.then you will know where the short is at
  • RoyB's avatar
    RoyB
    Explorer II
    No easy way i can think of.... Pull down the light fixtures and break connections that daisy chain to the next fixture. You want to find the segment that is shorted and abandoned it. Then you will have to run new wires from there I guess... This will be a major pain to fish new wires from one fixture to the next...
    I would use two conductor 'boat wiring' once you narrow down the shorted segment.
    Roy Ken
  • It would not be a break in the wiring. As you first described, this is apparently a short circuit. Can you disconnect the circuit from the fuse panel side, then use a ohm-meter to check for short circuits.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
