KD4UPL
Jul 01, 2018Explorer II
Your ground fault or short has nothing to do with the 12v fuses so don't bother with them. Sparking sounds like a short to ground. If you have the camper main off when it sparked it has to be in the cord.
You don't need a heavy extension cord to trouble shoot a ground fault or short. Even a light duty one will work if you have it.
You either have a neutral touching ground causing a ground fault or a hot wire touching ground causing a short. A direct hot to neutral short would not trip the GFI but would trip your circuit breaker feeding the outlet.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
