swimmer_spe
Aug 09, 2021Explorer
pianotuna wrote:
Likely it is a doorstop.
Here is what might be tried.
1. measure the voltage. If it is below 10 volts. Stop and use it for a core exchange.
2. if the voltage is ok, then barely cover the plates, and attempt to charge the battery at a low amp rate.
3. after the battery has charged for quite some time (24 hours), let it rest for 24 hours and check the voltage. If it is 12.5 or higher, then check the plates to make sure they are covered, and do an equalization charge.
But very likely #1 will be the path to follow.
It is old and a starting deep cell battery. No love loss on it.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 21, 2026
