MEXICOWANDERER
Jun 21, 2014Explorer
STOP! (Please :) )
This is a REVERSING POLARITY MOTOR. The polarity on the red and black wires + and - REVERSES with a switch. The metal body of the motor has no electrical connection to anything.
So connect your + and - jumpers to the red and black wire terminals and see what happens. Then reverse them. You should not see a heavy blue spark if the motor gear is disconnected from the load.
I got tired of screwing with the cheap switches OEM uses with slide outs, and now use a 100-amp Trombetta reversing solenoid. 30 amperes through a fast-on switch terminal is asking for a fire.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
