chiefward
Jun 22, 2014Explorer
EUREKA!!!! I followed your test procedure and the motor is working. The problem appears to be a sagging floor at the rear of the slide that is binding and causing the motor to cut off. Will try and adjust the slide to alleviate this problem.
Thank you very much for the lesson.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
