's avatar
Anonymous
Oct 02, 2015
Icemaker not working
Any basic suggestions. New Winnebago bus out of warranty so it's me to fix. Worked fine before
Thanks
  • 's avatar
    Anonymous
    Thanks. All steps taken. system worked in May. Will redo all steps. The contact is a new one for me. Thanks
  • It needs to be zero in the freezer to work. Have you checked the temp? If you turn the fridge on and put a bunch of food in it, it can take 1-2 days to get cold enough to make ice.
  • Just a couple of screws holding that ice maker in place. Could be bad contacts on the plug, clogged watrr line, or just not getting power.
  • Has it ever worked?
    Check 120 volt receptacle for power to the ice maker.
    Check the water valve in outside access for water.
    Have you lowered chrome arm in ice maker to turn it on?
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Mar 28, 2018
