BFL13
Mar 11, 2020Explorer II
opnspaces wrote:
^ BFL, can you clarify a bit.
Assuming the Original Poster (OP) has the original charge controller somewhere near the middle or rear of the RV.
Ignoring the inverter suggestion for a moment, You are suggesting putting the new Progressive Dynamics (PD) charger in the front storage compartment. This will allow the OP to run a much shorter charge cable to the batteries by going through the floor and up to the batteries on the other side of the wall.
The original #8 wire from battery to old charger/fuse panel can be left alone as it is what powers the coach. The only difference is that this #8 wire is no longer used to charge the batteries.
If possible the OP should find a way to disconnect and cap off the 120V AC and the 12V DC wiring that fed the original charger so it is out of the picture.
This makes sense as far as the battery hookup. But how does the shore power get to the new PD to charge the batteries? Would the OP run an additional three wire (pos, neg, gnd) from the original breaker box down through the floor in the rear and up through the hole in the front by the PD? If this is the suggestion and the user has an 18 foot run, would standard 14g wiring be sufficient for the 120v AC run?
Bringing the inverter back into the equation. Am I correct that your suggestion of running the shore power cord forward and into the front compartment is only for powering the RV through the inverter?
When running the trailer on batteries and using the shore power cord to the inverter. The OP must find a way to disconnect the PD charger to prevent a losing electrical loop. The loop being the batteries power the inverter which goes through the shore power cord to the coach. The coach then uses the newly added AC wiring to the PD charger and tries to charge the batteries. So the batteries are trying to charge the batteries.
Did I get it all correct?
I didn't say OP should get a PD (unless that is what he wants :) )
No need to disconnect the 120v from the WFCO. Just have a way to turn it off if going on inverter. He can then still have the WFCO to do 13.6 on shore power, and he can leave his -perhaps- PowerMax LK set to 14.8v up front to use when on generator off-grid. Saves having to adjust the voltage on the LK so much. Just for equalizing now. Or whatever.
If he sells the rig, the WFCO stays as OEM and he keeps his new converter for himself. It is a spare if the new converter dies for some reason.
There is no DC wiring that feeds the WFCO. Leave its output DC connected to the DC fuse panel as now.
Yes, you need 120v for the new converter up front. In the 5er I just used a receptacle that was on the front wall just inside where the converter was on the other side in the front storage compartment. Depends on the rig what you can do. Pass an extension cord from up front into where it cam be plugged into the nearest receptacle?
Unless it is an 80 amp PD that needs a 20a (120v) circuit and 12g wire, the converter up to 75 amp size will run on a 15a circuit ( a 100a PF corrected one will too) so 14g is ok.
On inverter, just unplug the front converter. The WFCO 120v is turned off however that can be done --add a switch to its 120v or use its breaker if it has its own breaker.
Yes, the shore power cord goes to the inverter after you arrive as part of setting up when off-grid. When you want to recharge the batts, you get out your portable gen, unplug the shore power from the inverter and plug it into the gen.
That means staying on gas to run the fridge going down the road. If you want to run the fridge off inverter going down the road, you need another way to run the cord.
The OP already has solar, so no need to change anything, but you can put the controller in with the inverter and new converter to get a shorter run to the batteries for the controller's output. That can mean not seeing the controller's display so often. Means find a wire route up to the solar panels from there too.
If you add a Trimetric or similar to the deal, now you need the 500a shunt up there with the new things, which means re-route the neg wires now on the battery neg, including the one to the frame. Your long wire to the monitor's display comes through to inside, same hole as for the inverter's remote.
If the controller inside has a remote temp comp wire to the battery bank now, then it must have gone through a hole, which might be useful.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
