Vintage465
Mar 11, 2020Nomad
Thanks for all the info guys. I still don't quite see the logic int he charge wizard and I think it's safe to say I must have read the manual incorrectly. My Solar controller though nothing fancy just charges like a big dog at 14.8 til the batteries are full then shuts down to float. I can set to automatically equalize every 28 days, it will equalize @ 15.3v for 3 hours or I can push a button to manually equalize. I've thought about mounting a converter in the front as mentioned and there is 120v right there, so that would be reasonably possible. Problem is, my little rig is very tight up there and fitting a converter in there will be pretty tight. I don't see the day I need an inverter. I'm a little un-easy about having to throw switch when changing my set up from genny to shore. I don't need another thing to remember! My buddy just toasted his converter forgetting to flip a switch. Kind of why I was thinking of going with some bullet proof(big)wire from a PD unit in the factory location. Everything would be as it was, except that it would work right.
Thanks for the help.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
