MEXICOWANDERER
Mar 14, 2020Explorer
Destranding
Solder the shaved tips. If the perfect shape is round with a set screw holding the cable file the soldered tip to fit the hole exactly. The solder should solidify far enough up the cable to make the tip joinery one solid mass.
The cable must be supported two inches or so distant from the tip to reduce tension on the device's copper terminals. The gain in conductivity of such a junction when done correctly is around 12%. Verified by 4-terminal milliometer
