Vintage465's avatar
Mar 10, 2020
If I went to a Progressive Dynamics Converter.......
So I'm always looking to my next upgrade for my charging of the 4-6v GC batteries. Knowing that the WFCO converter my rig came with is next to useless on it's own, add to that the fact that there is 18' of #8 wire to drop the theoretical charging voltage from a possible 14.4 to 13.4.
If I went to a Progressive Dynamics retrofit I'd be re-conductoring to #1 or #2 wire from the converter to the batteries. I was reading that their charging profile is to pack 14.4 or 14.6 volts to 90% of the charge. Then somewhat float it up to 100% with 13.5-ish volts? To me this doesn't really seem like that great of "wizardry" even though it's called the charge wizard.
For those of you who've installed them, how well does the wizardry work? I would only be using it when there isn't enough sunlight to get at least 90% with my solar. When we were at the Mojave Desert for Thanksgiving this last year I could have used it one day to bring my batteries to 100%
Thoughts?
Thanks,
  • If one wants to use thicker cables than will fit in the cable receptacles, there are adapters available, or one can simply destrand at the connection until it fits. It's not going to cause any measurable voltage drop or excessive heating destranding a 0 gauge cable to 4 awg at the connection. The thicker copper cable will help wick away any extra heat. Do be sure to retorque it after a few cycles though.
    The Pd is a good converter. The ability to manually force one of the three voltage stages is awesome. I am only annoyed by their marketing, calling the 4th stage , that 15 minute blast to 14.4 or 14.8 every 16 hours from 13.2v "equalization' instead of destratification.
    True equalization is accepted as applying voltages over 15.3v, to as high as 16.2v, after the battery has already been held at a regular absorption voltage until amperage quit tapering in order to max out the specific gravity of all cells. To call Destratification which is simply inducing gassing voltaegs for a period of time to stir the electrolyte, 'equalization', annoys me, but I still recommend their converters for those who require automatic, as at least this Automatic, has the option of manual override.
    I've installed two pd9245s for those needing automatic but liked the idea of manual override, and an Iota DLS-45 for the one person who said they would never manually override it even if they knew when why or how that would be desirable.
    I like the Manual powermax adjustable voltage models too. The older 100 amp model I have modified with a 60mm continuous running fan opposite the provided 80mm fan, and calibratable illuminated voltmeter on a switch, and with 10 turn 500 ohm bourns potentiometer, makes only 94 amps, but that is likely as it is near maxing out the 15 amp household AC circuit and is not getting 115vac+ from it. It goes as high as 15.5v. Adjustable voltage is great when charging in hot or cold climates or multiple batteries that ask for wildly different setpoints, or when one simply hates anything 'automatic' which falls so short so often that it negatively affects battery longevity and enjoyment one can have when the batteries are not prematurely dying from chronic undercharging in back to back nightly deep cycle duty.
    Powerpole princesses that rarely or never boondock, with their dual 12v group 24 marine/rv batteries are 'just fine' with the Manufacturer provided Wfco, until it fails anyway.
  • I have the Progressive Dynamics Modified 14.8 with the charge Wizzard,with the pendent I can put it into boost,14.8, mode when I want to. When I run the generator it will automatically put it into boost mode. When plugged in it will follow its normal routine of charging.
    It has worked out very well when boondocking and never failed to bring my batteries back up to 100%. Batteries are now 4.5 years old and in top shape,very little water use over that period.
  • Have the 9280 14.4V version. #4 is the largest wire that will fit in the converter lugs. The run to the T-105 Trojans is about 12 feet and I measure 14.37V at the battery terminals in "boost" mode. Have had the Trojans and the PD for 3 years. Hardly ever need to add water. Have had no issues with the batteries or the converter. Very happy with it.
  • #4 wire is fine and might be the max that fits the converter lugs.
    Consider a 9280-14.8 for maximum charge as long as your generator can handle it.
    Never read a complaint post on poor charging or shortened battery life with a PD converter. All top ratings.
  • Hi,
    I would look at the variable voltage Boondocker models.
    I mainly use an inverter/charger that allows me to program voltages.
  • Doesn’t sound like much of an upgrade for a bunch of money and time.
