MSGTRETIREDCSP's avatar
Mar 05, 2014
I'm Confused?
I just removed two 6v batteries from my fifth wheel rv. I'm going to replace them with two 12v batteries. When I removed the 6v batteries, there was one wire running from pos to pos on the two batteries. There were two large white wires from the rv and going to the neg post of one battery. There was also two large black wires going from the rv to the neg battery post of the other 6v battery. With the one wire that was running from pos to pos of both batteries, that tells me that they were both wired in parallel? Am I right? What confuses me is if they are both 6v batteries, wouldn't they need to be wired in series to get 12v in an RV that is 12v?
My fear is installing the two new 12v batteries. I don't want to wire the same only to find out it's wired in series. I don't want to screw things up with 24v.
Can you help me out? Thanks
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
