MitchF150 wrote:
Interesting.. I find gas works better for me, especially when it's really hot outside (80*+ and even in the 90's*). With the additional fan setup I now have, it really helps while on gas.
Mitch
BOTH LP and 120 have the SAME BTU output. But, there are variables that affect 120 operation. LOW 120 voltage(below 115) will cause lower BTU heat output, which causes people to think LP is better. So, you need to monitor the 120 voltage with a DIGITAL Meter, NOT those cheap needle wall RV plug in types. When the voltage drops below 115, operate on LP. Voltage drops are common in parks that are in hot climates with a LOT of RV'ers. Doug
