dougrainer wrote:
bob_nestor wrote:
First, absorption units do better on propane and 110v than they do on 12v. The 12v is only there to try an maintain temps while traveling.
Second, minimize putting warm things in, so limit the number of times and the length of time you have the unit open and try not to put a lot of things in at the same time that aren't already cooled down.
Third, they all work by transferring the heat to the outside via the cooling coils in the back of the unit. For most installations that uses just normal airflow over the coils - since hot air rises it brings in cooler air at the bottom and exits at the top. Units installed with a top roof vent work better than units with the top vent on the side. Most manufacturers don't follow the recommendations for clearances in the back where the coils are and usually allow too much space. Limiting the space to the recommendations using baffles and such helps with the airflow. Adding fans can help, but be careful. Just moving a lot of air may not be as effective as moving the right amount of air over the coils. Faster air can create a turbulent airflow and a laminar airflow is what you want for maximum heat transfer.
Finally, since the unit's performance is based on the ability to transfer the heat outside thru the coils, the temp difference between the air at the coils and the outside air is important. Try not to park your RV in such a way that the sun is heating the area where the refrigerator is located. And remember that at most the unit can probably create about a 40 degree F temp difference, so it will work better when the outside temps are around 70 than it will when the temps a pushing triple digits.
Are you stating that if the outside ambient temp is 95 degrees then (using your 40 degree), the Interior refer temp will at best be 50 degrees? If so, go back to school and learn RV refers. While outside ambient will affect the capability of an RV refer, I have to check and repair refers in 100 degree Texas heat all thru the summer. With all parameters(install and ventilation at spec), I can get a good cooling unit to produce 28 to 32 degrees in the lower section. There is No such thing as a "40" degree difference in RV refers. Doug(41 years working on RV's and Refers)
Mine must be broke, I get zero in the freezer & 35-36 in the refer.
