landyacht318's avatar
landyacht318
Independent voltmeters
A few months ago I installed 2 small, one decimal place, voltmeters on my Dashboard. One for each battery.
Each voltmeter has 3 wires (+), (-) and (+) voltage sense. The voltage sense wires go right to the battery terminal of each battery.
The ground wires of each voltmeter goto a nearby ground source, the same source.
When starting the engine on battery one only, voltmeter one will reflect lowered voltage anywhere from 1 to 2.5 volts before the engine catches.
But voltmeter 2 also drops, but only by 0.1v.
Is this because of the shared ground, or perhaps the proximity of the 2 voltmeters(about 2 inches apart)?
I'd hate to think my Blue seas manual Switches were leaking some current during engine cranking.
Not sure it is worth the effort of moving the voltmeter grounds to the battery (-) themselves, just to find out.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I too suspect shared ground.. On the house battery meter move the ground quite some distance and see if it improves things.. Move it to a solid metal brace or bolt somewhere, the closer to the house battery you get the better.
    Also, depending on the design of the meters where you get your 12v positive (Power) to the meter may make a difference but this,,,, Is LOW probability.
  • Thanks for the input.
    I do have fairly thick ground cables between frame/engine/ alternator/ firewall and shunt, and between shunt and batteries.
  • I vote for the shared ground as the cause. I agree not worth the hassle to run a separate minus wire. IMO the 0.1 volt drop is showing a pretty good connection of the battery to the chassis.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
