path1
Aug 16, 2013Explorer
I was able to get on with big needle nose plyers with the long handles. Came in perfect because I was wanting a pair of those anyways. Mine are the type that you screw on, no external noses or brackets $7 bucks each. One kept wiggling around, put in second little rubber gasket and torqued pretty hard and a little bit of lock tight. Also run gator caps, no more problems. But some people have some pretty fancy ones, if you do a search. I have steel OEM wheels. Measuring air pressure is like looking at your fuel gauge. Do so often.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
