wealthwise
Aug 17, 2013Explorer
oldbeek wrote:
Valve extenders cause more problems than they solve. Mostly slow leaks. Schrader makes a good truck air nozzle that will reach the inner tire stem. You can also buy stem caps with lead seals that are hex on the outside and a tool that will reach through the hole to install and remove these caps.
But I what if you can't get the gauge or compressor on the valve stem?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
