MrWizard
Jul 09, 2018Moderator
like it has been said
you have a loose//missing connection
not a short, a short will blow fuses,burn wires, stat fires etc..
maybe this will help you remember
if you take a short cut to your favorite 'watering hole'
you take a different route to get there faster
a short circuit is a faster way for power to get back to the other side aka complete the path to battery / ground
if you can't get to your watering hole because the street is blocked
that is the same thing as a loose connection, power can't get where it needs to go
dont worry we get a lot of people that ask about 'short circuits'
when its a bad/loose connection problem
a short is electricity going someplace its not suppose to aka working too hard too fast getting something HOT,
no electricity is like a clogged water line
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
