MEXICOWANDERER
Jul 10, 2018Explorer
Camping trailers are basic, so START BASIC
- Remove and clean the chassis negative (ground) wire at both ends
- Are the wire terminals connected to the battery not clean and shiny? Replace the ends
- There is a fuse panel somewhere? Behind it are screw or tab wire connectors -- shinem up
- Some butt may have a butt connector underneath the trailer to have one wire split into two. Usually people do a parallel splice wrong. Leaving a wire loose
- Use the existing lights burning as a reference.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
