- poncho62ExplorerCould also be a ground problem....Check all your ground lugs on the grounding bar near the converter.
- Old-BiscuitExplorer IIITypically that is a sign converter is failing.......can't maintain steady voltage
3rd converter in a 2006 vintage MH????
What brand of converters have you been installing?
Who has done the installs?
How are the batteries? Age, condition, water levels? - TucsonJimExplorer III've only had lights that varied in intensity, when the converter was failing.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
