beemerphile1
Jan 25, 2016Explorer
SkiSmuggs wrote:
....I still need to tap into power and the meter pedestal is 8' from the power connection on the RV. The pedestal is not commercial but simply a board mounted on two posts so adding an RV park box should be no problem. Tapping power is the problem. I will probably talk to my electric company first and an electrician after that.
The electric company will probably go HUH?. Then you will be transferred from one person to another and they will all go HUH? After an hour of being transferred from one person to another you still won't have an answer.
Just contact a local electrician you trust, this has nothing to do with the electric supplier.
