Rollnhome
Jan 27, 2016Explorer
Good luck. I see a knock out on the right hand side of the meter box. They may allow you have a small sub panel or breaker box come from there. Then to a plug. I would put a 50 amp RV and a 15/20 amp duplex also. Not a lot of room, may need to modify meter mounting post or put new equipment on plywood on backside of meter stand. You'll figure it out. More of getting approvals than actual work.
